Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Lenovo ThinkPad X250 repair page provides detailed guides on how to replace the battery, RAM, storage, and thermal paste. Additional information to help you fix your laptop on your own is also included.
Why is my laptop producing no sound
My laptop does not produce any sound even when at full volume. It is not on mute and I've tried troubleshooting and updating audio drivers
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires
Hi @alvin37808,
Can you hear sounds when using headphones plugged into the audio connector on the right hand side of the laptop?
par
Hi @jayeff,
Yes I can hear sound from the audio connector
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi @alvin37808
Check in Control Panel → Sound → Playback and check if the Realtek digital output is enabled.
If not click on the entry → Properties → Device usage → select Use this device (enable) → Apply
Indice 1
It's possible the cable to the speakers became loose or torn inside the case disassembly would be needed to clarify the problem
Indice 0
Ajouter une réponse
Alvin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 13
Total : 328
