Replacing monitor screen with tv screen .
I have a LED monitor (AOC E1670SWU) whose screen is broken and a tv (PANASONIC 22FPL5557/V7) whose motherboard is damaged i want to ise my tv acreen with my monitor motherboard please help me.
4 commentaires
Hi @omkumawat
I can't find any information regarding the TV. Please confirm the model number of the TV?
You would have to know the cable connector pinout for the wiring between the mainboard and the screen because if the screens are not identical in this regard or if they require different control voltages to operate then it won't work.
You would need to find the datasheet for both screens to know if they're identical or not and what signal voltage values are required to make them work.
par jayeff
can you give me a link where this information is given and how to compare data sheet I will be thankfully to you
par Dark fox
@omkumawat
As I said I cannot find any information regarding the TV model number that you posted. Are you sure that it is the model number for the TV?
To find the information you need you need to know the make and model number of the LCD panel for both devices.
This is usually found on the back of the LCD panel itself, so no doubt you will have to dis-assemble both the monitor and the TV to find it.
Also most likely the LCD panel might not be made by the manufacturer of the monitor or the TV as LCD panels are made by specialist panel makers to order and not by the end product manufacturer where they're used in.
Once you have the LCD panel information, search online for "(insert panel make and model number) datasheet" to hopefully find them, as this information is not always available online.
Without it it will be difficult to impossible to do what you want to do.
par jayeff
I founds data sheet but there is a problem my monitor lcd panel is 3.3v but TV lcd panel is 5v. can I give my lcd panel 3.3 volts
par Dark fox
