Vertical alignment very poor and seems impossible to fix
My wf-7710 has developed poor vertical alignment and the Epson procedure doesn’t seem to help. Indeed whatever I do seems to make things worse. The alignment page lines mostly show large white gaps in every position. I’m reluctant to dump it because everything else seems to work. What can I do?
Update (01/10/24)
Thanks for showing an interest. Here is an overall view of a printed page
and a closer view
an alignment page
and a closer view
4 commentaires
@epsonuser post an image of what a printed page looks like. that way we can see what you see and hopefully get you some idea on how to fix it. Ajout d'images à une question existante
par oldturkey03
@nick take a look at this one. See if you have an idea
par oldturkey03
The pics are of your vertical alignment.
Row 1 is alignment 1 so you have to pick the best vertical alignment.
So your row 1 i would pick number 4.
Row two looks bad but you will have to analyze which one looks best and then repeat. You should be at all 4’s when done
par Dustin
I am having this exact problem right now in my WF-7720 and my alignment pages looks just like yours. My printer is using sublimation ink. My nozzle check shows some broken lines so I am using a syringe and tube to put hot cleaning solution through each colour to try and get rid of any blockage. It helped me get line #4 to have solid boxes (it used to have the gaps between the vertical lines). But since then, I can see no change between alignment boxes. I changed the re-fillable ink cartridges to new ones and topped up each cartridge with fresh ink. Still no change. I print lots of purge sheets and they come out with some streaks, so my plan is to continue with the hot cleaning solution over the next month. If no improvement, I am guessing my printer head is defective maybe. After the cleanings and when I get ink flowing again, I try doing many vertical alignments but I can't tell aside from line 1 and 4 that there is any difference. If I get any new improvement, I will update here.
par Kerrie
