Aller au contenu principal
From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
18 questions Voir tout
New battery wear level 19% in a day!
I brougt a new battery for my laptop, it wear level in hwinfo was 0% the first day and only after 2 charges it is now 19.2% in just two days.
Should I return it and get a new one?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Hi @mohdafzal40548
Did you calibrate the new battery after you installed it?
Fully charge the battery and then run the laptop until the battery level drops to 10% and then recharge it again to 90%. Do this twice and then check if it holds its charge better.
If still no good it may be a faulty battery.
Indice 2
2 commentaires:
The battery need calibration? How is that done? I tried charging the battery and draining twice. The Laptop last for 3-4 hours.
par
@mohdafzal40548
Was it an OEM battery or just a compatible one?
I would get a new one given the rate of discharge that occurred.
par
Check if it's a OEM battery.
If it is not then that will be why it keeps going flat, unless it's faulty.
Indice 1
Ajouter une réponse
Mohd Afzal sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 15
Total : 115
