Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'iRobot Roomba i7 est un aspirateur robot doté de deux rouleaux extracteurs en caoutchouc pour une efficacité maximale, nettoyant les poils d'animaux et les sols multi-surfaces.
New battery doesn’t charge up to 100%
I bought new battery from the iFixit store but even leaving it charging for a whole night it never reaches 100%.
I followed the instructions to mount it, holding the robot's buttons before inserting the new battery.
To be on the sure I did an hard reset of the robot but the battery does not fully charge.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
@matteo80904 try what iFixit recommends: For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Now if you continue to have issues with the battery, I would suggest you contact iFixit. Since you bought the battery on iFixit, contact the service department: support.ifixit.com and let's see if they can help you further :-)
Indice 0
4 commentaires:
I’ve tried using the robot until it shut off but when it’s low battery it goes automatically to charging base. Any suggestions on how to fully discharge?
par
@matteo80904 have you tried to disconnect the base so the robot can’t find it or it doesn’t charge
par
@oldturkey03 thanks, it took 3 hours(new battery brought big improvement) but the robot got fully discharged and now the battery has reached 100%.
par
@matteo80904 Awesome! Repair is War on Entropy!
par
Im having issues with 2 different (both realtivly new) J7s i assume internals are the same as the i7 but both of them have intermittant charging issues where they both wont charge but after rebooting them they charge. should i try this method as well? to run it all the way then charge them?
Indice 0
Ajouter une réponse
Matteo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 21
30 derniers jours : 59
Total : 1,145
