Logic board interchangeable? ‘12 13” MacBook into ‘12 15” MacBook Pro
I have a mid 2012 13” MacBook Pro (i5 CPU) it works fine aside from battery drain off of the charger has become god awful
I have a 2012 2012 15” MacBook Pro that I bought awhile back that I have not been able to use because the drive cable on the drive bay is corroded on the motherboard (many different cables used to try and fix this)
I want to transfer the 13” logic board over to the 15” system is it possible to do so?
If it’s not possible is there any way to clean the drive bay connector on the motherboard or get it working?
Update (02/10/24)
Here’s a Photo of the area that has given me trouble. A person helping me tried multiple cables so unless he got 5+ bad cables it’s that port on the logic board/motherboard
I used rubbing alcohol and a soft bristle toothbrush this morning to try to fix it. Just building some Mac installers now to try to boot from
1 commentaire
@wesleytoulouse - Sorry where’s the pics? Did you leave them in the toolbox space. If you did go into edit mode of your question and then select the image icon in the far right, double click on the image to add it to your Q where the insert pointer is.
par Dan
