The Disc could not be read.
Red Error Message: The Disc could not be read. Please read the Nintendo Gamecube instruction book for more information.
@johnllovesr try and see if it reads an audio disk as well as different game disk then the one you were trying. Sometimes a disk can cause this error.
It is possible that this is either a dirty laser or a failing laser. First try one of those commercially available CD cleaner kits. Run that a couple of times. If that does not work you could could try to increase the power to your laser. Follow this guide. Just be moderate, you do not want to burn it out. The other thing to try would be a recalibration of the lens. For that follow this guide. After that I'd suggest that you replace either the lens or the optical drive. Remplacement de la lentille laser optique du Nintendo GameCube Remplacement de l'ensemble du lecteur optique du Nintendo GameCube
Tutoriel
Difficulté :
Modérée
30 - 45 minutes
Tutoriel
Difficulté :
Modérée
30 minutes
Tutoriel
Difficulté :
Modérée
30 minutes
Tutoriel
Difficulté :
Modérée
20 - 25 minutes
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 54
