Aller au contenu principal
Informations pour démonter et réparer la souris sans fil portable Logitech MX Anywhere 3. Commercialisée en 2020 et identifiable par les numéros de modèle 910-005986, 910-005833, 910-005987 ou 910-005985.
5 questions Voir tout
phantom clicking in Anywhere MX 3
Same problem addressed for Anywhere MX mouse, but since this model is different, I wonder if there's another solution.
This happened after around 1.5 years of use.
My partner has the same mouse and the same problem, using a different OS, so it seems to me to be a hardware problem.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
4 commentaires
Hi @glicerico
What had you tried? had you tried replacing the micro switch?
par
No, I don't know what the micro switch is or how to replace it. Is there a guide? If you are referring to the article I linked, I planned to do it, but saw in the comments that some people tried with the Anywhere MX 3 and didn't work for them
par
Ah, I think the micro switch is the module containing the clickable part. No, I didn't replace that, I don't have the spare part.
par
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
par
Ajouter un commentaire
4 Réponses
Solution retenue
Inspired in the guide for the Anywhere MX mouse, I opened the Anywhere MX 3, and although it's not built the same way, the solution was simple.
After carefully removing the 4 pads in the bottom of the mouse, then the 4 screws below them, I opened the mouse and saw the white elongated button responsible for the click.
I cut 3 small squares of black electrical tape
to fit the contact point with the click button on the other side, on the top of the mouse. I pasted the 3 squares one on top of the other in the place indicated by the screwdriver:
then just reassembled the mouse cover, screws, and pads.
This fixed the problem and now my mouse works as good as new :)
Indice 0
Yep. Same double click issue as all other Anywhere MX, appeared after 2 years of use after mandatory warranty ran out. Starting to believe this is deliberate design flaw. Has happened in 5/5 Anywhere MX mouses I have used.
Indice 0
2 commentaires:
sad situation
par
par
This is a problem, why this sites never advise people to replace the microswitch. Replace microswitch for left and right click and your mouse is like new again
Replace microswitch left click
Indice 0
1 commentaire:
where do you get the microswitch replacements?
par
Indice 0
Ajouter une réponse
glicerico sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 33
30 derniers jours : 112
Total : 764
