Replacement Battery for Apple TV Remote A2540
Trying to find a source for a replacement battery for the Apple TV remote model # A2540. Any help would be appreciated.
@danj, are you talking about the button cell batteries that older model remotes took? Because this one is completely different; it's a rechargeable Li-Ion square battery with the flex cable and Lightning port attached. I looked around but couldn't find any being sold.
At this point the only thing I can suggest is removing the battery and disassembling it to the point where the basic cell can be identified, then replace that alone, which would involve spot welding and/or soldering. The cells generally go by size and number of wires, so we'd have to know that before trying to locate one.
@charliedavies First thing to do is to pull the battery and get us some good pictures of the front and back sides. The main things we want to know are the dimensions (LxWxH) in mm and the number of wires connecting the battery to the flex cable. That will tell us whether there's a temperature sensor built into the cell itself or if it's just the battery's positive and negative terminals we have to worry about.
Once we know that, it's fairly straight forward to search for the particular cell needed; for example I have some cells I replaced in a concrete float whose dimensions were 3.5 mm thick by 70 mm wide by 95 mm long. So those numbers get combined into a single "model number" to search for; in this particular example the mode comes out as 357095. Searching for that number with the words Lithium Ion gives us sources for that specific cell. Here's an example.
Of course, your battery won't be anywhere close to this one, but that's how you go about finding it; two digits for the thickness, two for the width and two for the length and that'll get you cells that'll fit the physical space. Since Li Ion batteries are pretty uniform in power density, whatever you find should be very close to the original specs for mAh rating as well.
You may not even need to measure the battery yourself; the cells in the battery pack I was replacing actually had those numbers printed right on them, so that's all I had to look for. Note that the battery you find may or may not come with a BMS (Battery Management System) already built into it; if it does have one you'd probably need to remove it in order to use the cell with your existing flex cable and BMS.
Your right I was thinking of the older units.
Your answer is very helpful. I knew that it would require re-soldering both the ribbon cable and lightning connector. My real question is what model Li-Ion battery would I look for as a replacement?
You should be able to find it locally. CVS pharmacy or Ace hardware stores in my neck of the woods have them.
This remote doesn’t use the button cell battery. It has a rectangular battery with a cable that plugs into the internal circuit board as well as a receptacle for the Apple lightning connector.
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 72
Total : 281
1 commentaire
HI,
same problem,
we are not taking about the standard battery, ( the pill type one)
we are taking about the battery for the first gen
(the square black one that you new to remove by fully opening the casing of the remote)
Thank
par jsgagnon
