Aller au contenu principal
Mon téléphone à je pense un problème de batterie 🔋
Bonjour depuis un certain temps mon téléphone ne s'allume plus et n'affiche aucun chargement pourtant il n'y avait aucun problème signalé la veille je pense que c'est la batterie 🔋 et j'aimerais savoir si je dois automatiquement la changé
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@chanel24107 yes, you could try a new battery. First off try to reset your phone in recovery mode:
  1. Turn off your phone and wait a few seconds.
  2. Press and hold the Volume Down and Power buttons until you see the Android logo.
  3. Wait a few seconds.
  4. Do not delete the Wipe data/Factory reset, but exit out of this menu. If it came on when you tried to get into recovery mode, you know it is not your battery.
If your phone remains without any sign of life, replacing the sub-board (charging board) and checking the flex cable from the sub_board to the main board would be my next suggestions. Since iFixit does not yet have a guide for this, use something like this video to work on it.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@chanel24107 sí, podrías probar con una batería nueva. Primero prueba a reiniciar el teléfono en modo recovery:
  • Apaga el teléfono y espera unos segundos.
  • Mantén pulsados los botones de bajar volumen y encendido hasta que veas el logo de Android.
  • Espera unos segundos.
No borres el Wipe data/Factory reset, pero sal de este menú. Si se encendió cuando intentaste entrar en modo recovery, ya sabes que no es tu batería.
Si tu teléfono sigue sin dar señales de vida, sustituir la subplaca (placa de carga) y comprobar el cable flex de la subplaca a la placa principal serían mis siguientes sugerencias. Dado que iFixit aún no tiene una guía para esto, usa algo como este video para trabajar en ello.
Mientras trabajas en el teléfono, toma muchas fotos. Una vez que hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://fr.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Indice 0
Ajouter une réponse
Chanel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 76
