Why only two LEDs on my computer are lighted
I acciently pluged 220V, and the power supply bombed... and I replaced it with a good-working one. But only LED1 and LED2 are lighted, fans aren't worked, and only harddisk is still working. I tried three different RAMs and I'm sure Ram is OK. What's the problem???
10 commentaires
@highsheep have you had a chance to look at the logic board yet? Time to tear it apart and check for damage. There are plenty of capacitors that will take a hit on the 220V. Might be time to recap the beast anyway. We really need to see this board to assist you with that. Luckily schematics and board views should be available, we just need to know what your exact board number is. I suspect a 820-1540 All you have to bring to the table are the soldering skills and obtaining components :-)
Once you have your board removed. Take some good pictures (top and bottom) and post those with your Question. That way we can see what you see. Ajout d'images à une question existante
par oldturkey03
@oldturkey03 I put my pictures below
par Highsheep
@highsheep I guess it turned out to be a 1540 and they promptly place a sticker over it :-)
par oldturkey03
@highsheep you will need this for sure. LB# 820 1540 Start with the power block diagram and see if you get a feeling for it. Then take a look at all of the power rails (focus on page 7) Inductors and voltage regulator love to get destroyed in overvoltage situations. Anyhow, you will have to be okay with reading schematics, and basic testing of components. We can always assist but you are the hands, eyes and ears of this operation ;-)
par oldturkey03
@oldturkey03 Thanks, I'll have a try
par Highsheep
Voir 5 commentaires en plus
