Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
Right hinge is broken, can I replace screen with A1398 Early 2013?
Hello,
Thanks so much for the help.
So right hinge of my Mac 1398 Mid-2015 is broken and unfortunately is the one connected to the webcam and other cables (which I do not want to remove).
See the photos.
So I am thinking of changing the display, but my question is:
which model is compatible with the display?
I suspect that some displays are equal (A1398), but the cables are different. Can you help?
Video: https://streamable.com/ux3l9m
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires:
https://streamable.com/ux3l9m This is the situation right now.
par
This is the situation at the moment
par
@mirkounchained - Your video is hard to watch as you'er moving about to much and not stable long enough to really see things.
par
Ajouter un commentaire
1 Réponse
The A1398 covers a very large range of systems, sadly there are bumps along the road here as not all of the share the same parts or assemblies
Review this listing and instead focus in on the Model ID 15” MacBook Pro’s from 2012 ~ 2015.
Once you identify your system let us know, then we can get into how to fix your system. Review this answer MacBook Pro 15" Mid 2015 (A1398) right hinge broken
Indice 0
5 commentaires:
Yes mine is
https://everymac.com/systems/apple/macbo...
I have already seen this answer but unfortunately, my hinge is broken (cut in 2 pieces), so my only option is to change it or solder but to be honest I can remove it from screen, so solder the hinge can be very very difficult
par
@mirkounchained - Sadly soldering or welding won't fix this. You need a new hinge but as its hard to find the better answer is to find a junker which has a good lid assembly and if needed transfer your display over to the other frame.
par
Thank you so much for your help.
So I have updated my "question" with photos.
The hinge is the right one which is connected to the Webcam (I think and the Wifi Bar), you can remove the WiFi bar, but after that, there is the webcam cable inside the display.
So it is really complicated.
But since there are many A1398 I would like which display is compatible with mine. Thanks.
par
@mirkounchained - the red circled part is the camera which is mounted in the lid top bezel area. Give this a review MacBook Pro Retina Display Teardown it’s a bit of a job and you do need to be working in a good dust free area and be careful with the defuser sheets as any creases will show up as dark lines.
par
Thanks, what if I change all the display? which A1398 fit for me?
par
Ajouter une réponse
Mirko Unchained sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 144
