Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Réparez votre smartphone Samsung Galaxy S10 Édition 5G avec ces tutoriels de réparation DIY et pièces de rechange.
Blue connection not turning on
When I try to enable my Bluetooth through the status bar or in the settings the nob Icon will not turn on. However my wifi connectivity still works perfectly
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
5 commentaires
Did this happen after an update?
par
Please see if phone reset helps
par
@oldturkey03 I highly appreciate the feedback, I just tried the Safe mode trick and still had no luck. I now strongly believe that the issue might be hardware related.
par
@markusnorstroem Not necessarily, I used the phone for over a year and a half with the latest update. I believe the issue might be hardware related.
par
@i_am_the_cosmos unfortunately that did not work, I tried a network reset and still had no luck. Thank you for your input
par
Ajouter un commentaire
2 Réponses
Solution retenue
@bwalyamataka since your WiFi still works you may have issues on a component level. First you must rule out that this is a software issue.
First start your phone in safe mode. To place it in safe mode, use the Samsung instructions from here Once in Safe mode give it a try and see if it works now. If so, you know that you have a bad 3rd party App on your phone. It will not tell you which one so you will have to delete one after the other until you find the one that causes this issue.
If it does not get better in Safe mode, it is not an App etc. and you can exit safe mode.
Check the Bluetooth firmware version of your phone by dialing ****#2663#*** and see if it shows up properly. ******Anything after that would lead me to having to check the components on the board. Looks like your phone is a SM-G977. There are no free schematics out there but you can can get them through fee-for-service $$
Indice 1
@bwalyamataka
Try wiping the cache partition and check if that resolves the problem.
Go to Wipe Cache Partition → Samsung
Indice 1
Ajouter une réponse
Bwalya Mataka sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 409
