Aller au contenu principal
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
20 questions Voir tout
What makes the ABXY board to stop working?
One of my 3ds systems (new 3ds) used to work normally, but all os sudden it didnt turn on anymore (only if plugged in but didnt charge)
I took it to some repair shops but every shop told me that the repair wasnt worth it since the system needed a new motherboard.
I left the 3ds aside for some time, but didnt give up and kept searching online for a solution. After a long time i found that a possible solution was changing the ABXY board.
Since it was a cheap solution i decided to try it out. And it Worked!! But not for too long :( after one day or two it stopped working again.
So, what may be causing the abxy board to stop working? I want to fix my 3ds :(
Répondre à cette question J'ai le même problème
Indice 2
2 commentaires:
I would start with this guide and look for damage then give us images to give you a better diagnosis and hopefully a working 3ds in the end.
Remplacement de la clé C de la Nintendo 3DS 2015
Ajout d'images à une question existante
par
So after changing the ABXY board again, my 3ds is now working and charging.
Later, i will turn it off an on again to see if it keeps working.
par
Ajouter un commentaire
1 Réponse
The ABXY board may only be making partial or no contact with the contacts on the circuit board. If this does not work, you may want to use an eraser to clean the button contacts.
Indice 0
Ajouter une réponse
JAFA13245 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 81
