Why is the hotspot does not have the range
if u r using hotspot other phones wont get any range atleast close to the phone
Hi @jerohnjoshy
Check if the antennas in the phone are securely connected.
Here's an image taken from this teardown video showing where to check.
(click on image)
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 23
Total : 247
6 commentaires
It could be your antenna, how is your bluetooth connectivity range?
Is it the same of longer?
par Hampter
yes even the bluetooth is also same like hotspot
par Jerohn Joshy
@jerohnjoshy
What's the phone's normal WiFi connection distance like e.g. when connecting to a WiFi router?
It should be further than BT as BT is only ~30' (10Metres) due to less power being used for BT even though they use the same antenna.
par jayeff
@jerohnjoshy is it giving a hotspot to someone else or someone giving you a hotspot
par Hampter
@hampter hotspot to someoneelse
par Jerohn Joshy
Afficher 1 commentaire en plus
