Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Google Pixel 7a est la variante orientée petit budget de la série Pixel 7. Sorti en mai 2023, le Pixel 7a améliore le Pixel 6a avec la reconnaissance faciale, 8 Go de RAM, des caméras fortement améliorées et la recharge sans fil.
Screen adhesive re-use
Just completed a glass/screen repair on a Pixel 7a, but got a smudge on the front camera lens during the process. Sadly, didn't notice until after reassembly was complete. Can I re-open the front, clean the lens, and re-close without replacing the perimeter adhesive, or do I need to clean up and use new glue?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Thanks folks, for the minimal cost of new screen adhesive, it's worth the reassurance that it'll be properly sealed.
par
Ajouter un commentaire
2 Réponses
Solution retenue
I'd say it depends on how well the glass comes off. I had an iPhone X that I had just finished working on but banged my head on the table when I realized I'd forgotten to reprogram the True Tone data. So I opened it back up and found that the precut adhesive had stuck on the phone so it was still completely intact and undamaged. That being the case, I decided to reuse it and haven't seen any problem as a result.
So my take on this as it applies to you is, if the display comes off cleanly and doesn't tear or stretch the precut adhesive, you can probably get away with reusing it. If it sticks partly to the screen or tears / stretches when you get the screen off, then it's time to replace it.
One thing you might do when you put the phone back together is to reheat the adhesive once the screen is on, then place it face down with some weight on it. That'll soften the adhesive and the weight will help seal it. Hopefully that'll help compensate for not using a new sheet of adhesive. I usually go over the phone for about 3 minutes with a hair dryer, then I have a motorcycle battery I set on it for a half hour or so.
Indice 2
You could, But I would highly recommend not to
Indice 0
2 commentaires:
Not nay-saying your answer, I'm genuinely curious: voice of experience, or theoretical problem potential?
par
There’s a potential problem
par
Ajouter une réponse
Frudougy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 60
Total : 1,134
