The third redesigned generation Grand Vitara was introduced in 2005. The Grand Vitara is called Escudo in some markets. Also, in some markets the three-door variant drops the "Grand" to be branded simply "Vitara". In some countries, including Chile the 5-door version is named Grand Nomade.
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
2 commentaires:
Did you check to see if it is getting voltage? Good grounding connection?
par brandon k
Hi @abdul45226
What is the year model of the vehicle?
have you checked if the appropriate fuses for the headlight are OK?
par jayeff
