It sounds like you're experiencing an issue with a device that has stopped working and won't turn on, even when the power cord is plugged in. This can be frustrating! Let's try some troubleshooting steps:
1. Check the power cord: Ensure it's securely plugged into both the device and the wall outlet.
2. Power button: Try pressing the power button for a few seconds to see if it turns on.
3. Outlet: Verify that the outlet is working by plugging in another device.
4. Battery (if applicable): If the device has a battery, try removing and reinserting it.
5. Reset: Some devices have a reset button; check your user manual or online documentation.
If none of these steps work, it's possible that the device has a hardware issue or needs professional repair. You may want to contact the manufacturer's support or a authorized service center for further assistance.
Let me know if you need more help or have any other questions!
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
1 commentaire
@dennisatherton
What's the make and model number of the laptop?
Do you have a DMM (digital multimeter)?
If not have you access to a another known working compatible laptop charger?
If there's no life signs at all, the first thing to prove is that the charger is supplying power to the laptop. If for example it wasn't then the battery would have not charged and would've discharged during use and therefore it can't be used to start the laptop either
par jayeff
