Aller au contenu principal
Guides and repair information for Altec Lansing speakers.
20 questions Voir tout
Altec Lansing inMotion iMT800 no power at ac adapter
I am having the same issue as others I have read and also the batteries work. So I was wondering if a cord that is a wall outlet transformer that is 12v dc could be spliced and ran to the battery terminals 1st positive and last negative, independent terminals? Would that not be the same as 8 d cell batteries?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
This question was migrated from https://meta.ifixit.com/Answers.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hi @mandykelly
Doing this would mean having a cable permanently attached to the speaker which may be bothersome. It also needs to be tethered correctly so that flexibility where it leaves the speaker would be minimal ensuring that there's no strain on the cable connections in the speaker.
Other than that you may have to check what the current rating is on the adapter that you have now that you wish to bypass, to ensure that the replacement 12V supply can supply the same amount of current and not less.
Indice 1
1 commentaire:
@jayeff Thanks for your reply.i think im gonna try the fix linked below but if i try the reroute of power I’ll post a pick or two of how it turns out.
par
i had this happen many years ago on my IM810
i had to disassemble and re-solder a cable on the back circuit board in order to get the wall cable to work again. Apparently this happens on some of them because of heat. there was once a how-to guide on imgur, but the pics are now gone.
https://web.archive.org/web/202306080054...
if you REALLY need it, i can disassemble mine and snap a few pictures for you
Indice 0
1 commentaire:
@toro34….. you are awesome thank u so much for that. I had seen it before but I couldn’t find it recently! This made my day!
par
Ajouter une réponse
Mandy Kelly sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 21
Total : 57
