Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz) ou 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
Black sticker/tape on 15" 2014 MacBook Pro Cpu or gpu
I was repairing a 2014 15" MacBook Pro and accidentally removed the black sticker/tape that was surrounding the cpu or gpu, could this cause any problems or can I reassemble the machine as normal? if this could cause a problem could I replace this with something like electrical tape?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Looking at this image can you tell us where you found the black tape
Indice 0
3 commentaires:
it was around the dies on the large chip in the center that has 2 die sections, I assume it was either for heat dissipation or to prevent it shorting on the heat sink.
par
@jude85858 - Ok, the issue here is this is a thin piece of heat resistant bakelite which is why it crumbled when you lift it off as it’s not very strong. Electricians tape is not what I would use, I would use kapton tape (polyimide tape) likely a few layers as it tends to be thin.
par
Ok, thank you! I just ordered some.
par
Ajouter une réponse
Jude sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 41
