Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
20 questions Voir tout
Why is only low battery display popping up after battery replacement?
Replaced my battery per instructions but laptop does not boot. It only shows low battery display when plugged in. Light on charger will turn orange for 20-30 seconds then flash to green for 5 seconds before repeating again.
Left charger in for 20+ minutes and still nothing.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Are you using an 85W charger? If you're using a lesser wattage it may not be enough to power on the 15-inch from a fully discharged state. Otherwise, you could try an SMC reset. If everything else is correct, it could be the case that the battery you installed is faulty which unfortunately sometimes happens.
Indice 0
2 commentaires:
Yes, using an 85W charger and have done an SMC reset and still the same issue.
par
Darn, that makes me think the issue lies with the battery you installed. Were you getting these symptoms before the battery replacement? Good luck!
par
Let’s get a better view on things. Install this gem of an App! CoconutBattery paste a screen snapshot of the Apps main window and post it here so we can see it.
Indice 0
Ajouter une réponse
AB1 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 11
Total : 32
