Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
20 questions Voir tout
Can I replace 2.2Ghz Logic Board with 2.5Ghz +
Hi,
I have a MBP Mid 2015 15" and my logic board simply stop working so i want ot replace it with another compatible logic board. i look everywhere and found similar logic board but the speed is 2.5Ghz or more. so now i'm curious about what will happened if i replace my original board with this extra speed board. will there be any issue?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
These are the compatible logic boards MacBook Pro 15" Retina Display Mid 2015 Motherboards take note there are two variations the iGP and the dual GPU models. The heat sink is different between the two so make sure you chose the correct board. But it makes no difference which one within the sub group. Lastly, here’s the needed guide to do it Remplacement de la carte mère du MacBook Pro 15" Retina mi-2015
Indice 1
1 commentaire:
Thank you for you reply. it looks like mine is (IG) Integrated graphic board. i can only see one chip.
Edit: Can i still use (DG) if everything comes complete set including the heat sink?
Thanks
par
Ajouter une réponse
Itsmeapple sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 37
