Dead pixel after logic board replacement
I recently completed two repairs on my MacBook pro:
- Replaced the logic board using this guide
- Replaced the factory SSD with a Crucial P3 Plus SSD 1TB M.2 NVMe PCIe Gen4 Internal SSD and a M.2 NVMe SSD convert adapter card
The MacBook operates fine but there is now 2 or sometimes 1 dead pixels in the center of the screen. I presume I've damaged something or done something wrong in the process of replacing the logic board but I just wanted some help on where to look. I removed the display data cable and reseated it but it still has the same issue.
On another note the upgrade to Monterey which is the final compatible version always fails. It just says "Upgrade failed" and boots into safe mode. When I restart it it goes back to Big Sur.
Any help would be appreciated!
2 commentaires
Which version of the logic board did you install? A dual GPU or the iGPU only model?
As for the OS installer failing that can happen when the SSD has issues. Using an M.2 SSD with an adapter is not as stable as a direct pin compatible SSD. Do you have an external M.2 case which you can mount your current internal SSD into and then try re-installing. If that too fails using a fresh SSD in the case or a second external drive which can be reformatted and setup as a bootable drive try getting it working. Let us know how it goes.
par Dan
@danj Its the Radeon M370X version so I think its dual GPU.
Thats interesting regarding the SSD, I managed to update it from High Sierra to Mojave, then Mojave to Catalina and finally to Big Sur so I thought the SSD was solid. As you say the adaptor could be problematic but I may have seen the issues on the other upgrades in that case.
par Adam Wilson
