Lifted both PD203 pads. Need Alternative Pads
My power supply component went bad and I replaced it, but I lifted up both the pads off the board. I thought I repaired it. I can't get a good pic of what I done, but I tested the connection's ohms with a multi-meter and it is coming up to 4.635.
4 commentaires
positioning your phone slightly away from the object you are taking picture of can be useful. The phone cannot focus on something that's too close to it, so you get a blurry picture.
The minimum distance (for my phone at least) is around 8cm, or 3 inches.
Yeah even a picture search (https://i.ebayimg.com/images/g/eVEAAOSwZ...) is a bit too blurry (low-res, mostly) to tell anything.
It's the front side, below the power connector.
par Xavier Jiang
@repairpers23434 besides a better picture we will also need to know what motherboard this is. It looks like it could be a NM-C371 or a NM-C372. Applying jumpers etc. will not be an issue for as long as we can see what damage you have and what this all looks like. Remember, since you will have to do some soldering, you might as well remove the board. That way you can actually find out what we still need to know.
par oldturkey03
@oldturkey03
Just checked the circuit for PD203 and it is the same for the NM-371 and NM-372 motherboards as it is for an NM-C221 as shown below
Cheers
par jayeff
@cdr_xavier I will take another screenshot. My phone is not the best, so the picture quality will be still bad.
par RepairPerson
