Suggestion for iPhone 3GS take apart/logic board
Hi,
As I found over the weekend there is a copper antenna that touches the outer frame from the logic board. As anyone that has to use your take apart obviously will have no experience I'd like to suggest you include a note about the antenna it's purpose and position. It is easily damaged or broken if manipulated (As I found out) and I'm sure it would remove a lot of "No cell Service" questions :)
And FYI I gently used a sonicare toothbrush to remove all the corrosion from my logic board, dock connector and SIM card slot and it worked a treat. I'd tried to use a soft brush multiple times but it was not removing all the corrosion.
My iPhone lives after going to the bottom of the pool!
