Aller au contenu principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429 questions Voir tout
Why does Mac OS X fail to install?
21.5 inch Mid 2011 iMac
In an effort to make the computer brand new, I decided to reinstall Lion. After a quick Google, I erased the hard drive using Disk Utility & restarted in Recovery Mode. I clicked the "Reinstall Mac OS X" option and agreed to the terms, and chose destination to install. It then downloaded a fresh copy of Lion and rebooted to the Mac OS X Installer. Less than a minute into the installation an error pops up:
"Mac OS X could not be installed on you computer.
Mac OS X can't be installed on the disk Macintosh HD, because a recovery system can't be created. Visit http://www.apple.com/support/no-recovery to learn more.
Click Restart to restart you computer and try installing again."
I've retried at least a dozen times with the same results. I know there is a solution out there, but it has evaded me for the past two weeks. Any advice would be appreciated more than you can imagine.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Solution retenue
Try installing a 10.6 system from your original system installation disk, do the updates to 10.6.8 then install Lion and update again.
Indice 3
1 commentaire:
Check with Disk Utilities to see if you've formatted the drive GUID. Still failing? Do a reformat using the "write zeros" option to map out any bad blocks. This failing, your machine may still be under warranty, get a replacement drive. You are using the original hard drive, correct?
par
I had this same issue. I fixed it by booting into internet recovery mode (Cmd+Option+R) and then opening Terminal from the file menu and using diskutil to delete the highest level Logical Volume Group as shown here Erasing a FileVault 2-encrypted Volume -- Then closed Terminal and opened the Disk Utility GUI tool. Created a new partition. Closed Disk Utility and then ran the install again and it worked!
Indice 1
1 commentaire:
Matt good find!
par
It sounds like your boot table is corrupted. Have you run Disk Utility and reformatted the drive with the Mac OS Extended journaled format?
Indice 0
2 commentaires:
When i try to partition the hard drive, it fails with the error: Couldn't unmount disk.
par
You may try a third party format tool to see if it can fix the drive otherwise it sounds like the disk is bad
par
Every time I hold cmd+Option+R it tries to do an internet recover and does the whole process again
Indice 0
Ajouter une réponse
Bastian sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 15,043
