I can't even with this thread..
I'm gonna keep this in simple English, avoid tech lingo (cause we're here to learn - not make a point), and I realize a lot of you had good/correct ideas but I feel like I didn't get an answer to OPs question because there were so many.
Please open your tablet first (please disconnect the battery before disconnected anything and try not to use metal tools on the contacts!)
Look at everything and if you notice anything that looks weird you should post back here so we can get the right help for you and anyone else having issues.
You might notice the port is connected to a smaller logic board
- if it is it'd be easy to just buy ~that~ part and replace it (yes I realize it doesn't sound cool and there are so many theoretical complications but I trust your judgement and think you'll do fine as long as you try your best!) but seriously don't get the wrong part and break it - please. If you need to see an example what I mean you can Google search a Galaxy S5 Charge Port with flex ("ible cable"), or look at how the Nexus 7 (2013) looks. Yes most of those types have other parts on them so you'll probably want to have a warranty of some sort. Also I have to say this - make sure you're not just buying the whole board (unless you want to) and match everything you can. Size, shape, color, carrier, model number, etc)
If not, please just be careful and if you haven't soldered anything before it might be best to not attempt it and visit someone who will repair it and warranty their work.
^^^And that's the answer - below is irrelevant unless you want to.
I'm not going into how to solder because I'm sure the information is out there, however if that's what someone wants I suppose I can. But make sure you have flux, a soldering iron, people have their own preferences on what solder to use (but there are a couple forums on iFixit about that exact question), low melt solder, a magnifying lens, and a steady grip. (it'd be nice to have an ESD mat too, just avoid building up static, you can touch a metal surface before touching the tablet, and if you can avoid working while standing on carpet.
Yes, this should sound like you gotta go through ~some~ trouble and if you don't work or live somewhere with these things available, it'll probably cost some money to get those things, and although anyone can learn to do this, I wouldn't recommend trying it on something you want to keep the first time you do, if you've soldered bigger things before, its a little different and each contact needs to not have solder touch the other ones. There are tricks to do it quickly and efficiently (ish). Also I have customers always ask me this and I understand but not every port is the same, I wish I could carry hundreds of a single port and it'd be the right one for every device but again check the model.
I'm assuming you want to fix the port and not jerry-rig it - a model number/name would help OP. Please comment if you have any concerns with this comment since I don't want to give anyone any bad info.
Thanks!
A voté
Annuler
Indice
3
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
22 commentaires
If its under a year old don't wait there is a free warranty If its broke u don't need a warranty in the store Just call the manufacturer And tell them its broke and they will replace it hopefully
par wes mix
Thank you Ashley for posting this question because i am actually having the same problem to. :D Please help
par Amelia Winifred
Thank you so much it worked well not really but thanks fro the advice the person that wrote this::
Uhh..get a safety pin or any type of sharp pin. The charger port that's broken, stick the pin in and slide around the outsides, and see if any dirt comes out. If any does, then thats the problem, and if any doesn't, then YA CAN'T FIX IT. If you wanted to fix it, you would have to pay alot, so its no point if with that money you can just buy A NEW ONE! Hope I helped, good luck.
Because it did work and dient wat i did is i got a sowing pin and fixed the socket things and walla it worked thatnks So much
Your sincerly x Amelia winifred
par Amelia Winifred
take case of strip small bit wire from black and red wire on battery. get old usb lead remove outer wire to revael 4 wire strip black and red conect to wires on bterry and plug usb into pc/laptop it will charge do this myself (last resort but it works)
par andrew ford
«Its an phisical damage we can't fix devices like that»
It's what the warranty said to me
par kutariamoto
Voir 17 commentaires en plus
