Aller au contenu principal
« Retour à Toutes les histoires
iPhone 5s Battery Replacement
Tom -
iPhone 5s
Image de l'histoire
  • Image n° 1
  • Image n° 2
  • Image n° 3
How to replace the battery in your iPhone 5s
30 minutes - 1 heure
Moderate
Mon problème
The battery went dead very fast.
Ma solution
Removing the battery was incredibly difficult. I installed the new battery but had to put phone back together 5 times before I could get the screen to work. I had no problem with parts I got from iFixit.
Mon conseil
When removing the battery try not to fold the battery at all. If the battery folds it can cause a short and explode in your phone this is what happens when trying to remove it. Try to make sure your battery is dead all the way before you change it.
Image iPhone 5s Battery
iPhone 5s Battery
$29.99
3 commentaires
The 5S battery is a real pain to remove. at th ebottom of the battery is a black plastic tab that you can pull on to remove the adhesive holding the battery in place, but 9/10 time it rips off without removing the adhesive.
The only way I have found to get the battery out without it bending too much, is to use a heat gun and heat up (not too much!!) the back of the phone where the battery is sitting. Then use a thin flat spudger or similar to get under the battery. Normally the battery casing rips as the glue holding it in place is overkill on Apple's part.
Harvey - Réponse Partager
When you first remove the dock connector, you can really easy pull the black plastic tape without breaking it.
Marvin - Réponse Partager
Tom,
Im sorry you had a difficult time replacing the battery on your iPhone 5s. For first timers it can be a bit tricky. For future repairs on your mobile devices by all means contact me for help or advice just click on my name gillrios to get me email and contact info for my business G3 Mobile.
gillrios - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 648
