Aller au contenu principal
« Retour à Toutes les histoires
my first iOS, iphone 5s device
sr.hardwaremann -
iPhone 5s
Image de l'histoire
How to replace the battery in your iPhone 5s
40 minutes
Easy
Mon problème
The battery died while it was charging.
Ma solution
my smarthphone (moto G 4G) came in short circuite 'forcing me to buy a new device . It was when I won got an iphone 5s that was damaged about two years ago' 'according to the former owner
he would simply have switchinitiallyed off while charging and never back life .
initially I feit totally without option in front of the torx t5 'entry since it was not a very common tool, I went to all the university labs (even in the apple lab) , '15 days of searching were necessary for me to achieve the only torx key, However my suffering was not over I still needed a suction cup there if there were another 4 days of searching until my patience was over 'I went to practice with what I had in my hands ...
it was there that I met the ifixit, I studied the images tutorial carefully and put my hand in the dough, I took the bad screws I still needed to pull the screen, after a few frustrated attempts I had the idea of ​​using tape duplaface 'is worked out! (the hell was to remove tis tape the screen later) ...
  with the device finally opened I removed the flat of the id touch and removed the screen with that surgical care to not have so much work lost by sloppiness, ' I still had to withdraw the battery' but there was nothing to heat so I saw an iron for clothes I grabbed the bridge of my shirt and wrapped the iphone in it used the and iron it, the battery came out easy!
I took the multimeter and saw that she was dead '' I threw some tension until she came back to life 'visibly everything was okay with the device I looked for oxidation marks some short mark and had nothing was everything perfect' 'I knew there was something wrong or with the logic board or the battery.
after checking everything I decided to reassemble the device and he simply started charging and after about 10 min he open apple logo and inicialing is it works until today I was suspicious for months just hoping he would give some problem but he is perfect , the battery is genuine
I have the theory that somehow the source or cable or socket caused a short in the battery causing it to die, and the interval of almost 2 years has served for her to forget the trauma caused by the short,
I already researched a lot and I did not find a good explanation for that.
Mon conseil
always use your creativity!
Image Hakko 3 SA Tweezers
Hakko 3 SA Tweezers
$9.99
1 commentaire
Love your phone case!
Aiden - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 681
