Aller au contenu principal
« Retour à Toutes les histoires
Sony a65 Main board replacement
HITGFRY -
Image de l'histoire
Mon problème
Camera would not power up. I found that the CMOS battery receptacle solder points had come undone. I tried to re-solder but it didn't work. I think the poor connection damaged something else in the mother board. I purchased a manufacturers refurbished MB on eBay for $159.00.
Ma solution
Replaced the main board. It went well but not as fast as the tutorial said but that's to be expected first time through.
Mon conseil
DO NOT install the CMOS battery until last thing before you put the plastic covers back on. The battery receptacle will break very easily if you ham hand the battery installation, I broke a tab but was able to secure it with super glue. Make sure you put screws on a non-metallic tray with a lip so they won't roll away and lay them out in order as they are removed.
Image iFixit Precision 4 mm Screwdriver Bit
$2.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 369
