Aller au contenu principal
« Retour à Toutes les histoires
MacBook Pro USB port fixed!
David C Black -
MacBook Pro 15" Retina Display Mid 2012
Image de l'histoire
  • Image n° 1
  • Image n° 2
  • Image n° 3
MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement
1 heure
Difficult
Mon problème
USB port was completely unresponsive despite several software reset and other attempts.
Ma solution
Everything was quite straightforward with the guide; however, one aspect was not documented. The I/O board *data* cable replacement has no guidance. After looking at the problem, and because I did not have reason to suspect it was broken, we decided to forgo replacement. The decision was correct. Unfortunately, that means we spent an extra $19 we did not need -- it had been obtained because the parts list indicated it was necessary. We had opened the parts packages up before starting. So I am not sure it can be returned; although, as a simple cable it is unlikely we could have damaged it.
On the other hand, the I/O board cable was needed as it is fairly fragile and removal may or may not leave it in a decent condition.
Mon conseil
Buy some double sided tape to help stick parts back down.
I have some photos detailing routing of the camera/airport cable.
Be careful not to cover the I/O board data cable as you put the I/O board back. I had to remove the board to extract the hidden cable.
The iFixit magnetic board helped a lot to keep screws in the right place. Be sure to put them on the board in a manner that helps you know which goes where.
Image MacBook Pro 15" Retina (Mid 2012-Early 2013) Right I/O Board
$34.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 310
