Aller au contenu principal
« Retour à Toutes les histoires
Petzl Headlight button repair
Gavriil Kamaris -
Image de l'histoire
  • Image n° 1
  • Image n° 2
Mon problème
The rubber covering the On?Off button was destroyed after years. The PCB was revealed making the circuit vulnerable to dust and moisture and the button difficult to locate.
Ma solution
I cut a transparency slide oval part to avoid the glue going all over and create a spring like behavior and also designed and 3D printed a small pin to push the button. Then i covered the assembly with mouldable glue (like sugru) to reform the rubber cover. All went well and the button is working fine
Mon conseil
Please contact me if you need any designs for the 3d print pin.
1 commentaire
Well done! 👌Will come back to this when my Petzl button fails
Susanne - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 251
