Aller au contenu principal
« Retour à Toutes les histoires
Power supply replacement
lazzeostergaard -
Image de l'histoire
  • Image n° 1
  • Image n° 2
  • Image n° 3
Mon problème
I bought an Imac 24 on the Swedish ebay "Tradera" guessing that there was a problem with the power supply. Thanks to the guide here on ifixit I thought that I give it a try so I ordered a new power supply, 3 screwdrivers and suction cups.
Ma solution
Thanks to the guide on ifixit i managed to replace the power supply in half an hour. I was very excited when I first pressed the power button and I could here the apply startup sound, however, the power supply was not the only part that was corrupt. The hard drive was also bad so I had to take the Imac apart one more time to replace the hard drive (had one 1 TB laying around).
Mon conseil
It is a good idea to be 2 persons doing this repair. If one can hold the LCD you don't even need to disconnect the LCD. That will save you some time.
Image T6 Torx Screwdriver
T6 Torx Screwdriver
$9.99
Image Heavy-Duty Suction Cups (Pair)
$16.95
Image TR10 Torx Security Screwdriver
$5.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 17
Total : 57
