Aller au contenu principal
« Retour à Toutes les histoires
iMac HDD Replacement
Joseph Abraham -
iMac Intel 20" EMC 2133 and 2210
Image de l'histoire
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
1 heure
Moderate
Mon problème
Original hard drive went bad, had to replace it.
Ma solution
Repair went smooth. However, I did forget to attach one cable prior to reassembly. I had to open the unit back up and reattach the video cable. I ended up actually shocking myself because when I reopened the computer, I forgot to unplug the computer.
Also, wasn't able to install the operating system from the DVD drive for some reason. I ended up cloning a drive that was plugged in via USB; I used disk utility.
Mon conseil
First, never work on an iMac when it is plugged in. There is a possibility of lethal electric shock. Second, in many instances, cloning drives with disk utility is more time effective than reinstalling from recovery disk.
Image 4 TB 3.5" Hard Drive
$172.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 9
Total : 212
