Introduction
This guide shows how to remove the door speakers in the 1994-2001 Integra. For models with component speaker systems, this guide only shows how to remove the woofers.
The method to remove the driver's side door is shown. The passenger's side is almost exactly the same, except there is no connector for side-view mirror controls.
If you are installing after-market speakers, it is not necessary to splice any of the factory speaker wires. Using speaker adapter harnesses makes the task very simple, providing an easy plug-and-play installation.
Ce dont vous avez besoin
Remove the plastic Phillips screw towards the front of the door panel.
Use a flathead screwdriver to remove the plastic clip that holds the screw.
Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
Use the same method described above to remove the connector for the tweeter.
Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
Remove the four Phillips screws that hold the speaker in the door.
Lift the speaker out of the door. It is still connected by a single connector.
Press down on the tabs on the speaker connector, and pull it directly away from the speaker.
3 autres ont terminé cette réparation.
Un commentaire
On my 2000 Integra GS 2-door model, this was much easier than described here. I didn't have to take off the door panel at all. I just popped the speaker grille off with a flat-head screwdriver, and the speaker was accessible from there.
To remove the speaker grille, pry from the bottom side with a flat instrument and the bottom edge will pop out. The top edge has tabs that have to slide down for grille removal.
My front speakers (6.5" size) had 3 screws mounting them in. All 3 screws were accessible after removing the speaker grille. To remove the speaker, take those screws out, then tilt it forward so that the top edge leans out first. Then you can lift it up and out far enough to reach the wire plug and press the plug release clips with your thumb and forefinger to unplug it.
Not much else to the job of speaker removal, for the front ones. The back ones are more difficult though - you must remove the rear side panel to get those out. But it's definitely worth it to replace those dull-sounding factory speakers with some aftermarket ones!
