Aller au contenu principal
Pour réparer ensemble - Je crée un compte
4Sight 9 Battery Replacement
Ce dont vous avez besoin
  1. 4Sight 9 Battery Replacement, Cover: étape 1, image 1 de 2 4Sight 9 Battery Replacement, Cover: étape 1, image 2 de 2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. 4Sight 9 Battery Replacement: étape 2, image 1 de 1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
    Demander à FixBot
  3. 4Sight 9 Battery Replacement: étape 3, image 1 de 2 4Sight 9 Battery Replacement: étape 3, image 2 de 2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
    Demander à FixBot
  4. 4Sight 9 Battery Replacement, Battery: étape 4, image 1 de 1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    Demander à FixBot
  5. 4Sight 9 Battery Replacement: étape 5, image 1 de 2 4Sight 9 Battery Replacement: étape 5, image 2 de 2
    • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
    • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
    • Repeat previous actions until battery comes loose from device.
    Demander à FixBot
7 autres ont terminé cette réparation.
Jack Applegate
Membre depuis le 04/07/15
439 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 42
Total : 2,210
