Aller au contenu principal
Pour réparer ensemble - Je crée un compte
ASUS UX50V-RX05 Optical Drive Replacement
Ce dont vous avez besoin
  1. ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: étape 1, image 1 de 3 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: étape 1, image 2 de 3 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: étape 1, image 3 de 3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    Demander à FixBot
    Ajouter un commentaire
  2. ASUS UX50V-RX05 Optical Drive Replacement: étape 2, image 1 de 2 ASUS UX50V-RX05 Optical Drive Replacement: étape 2, image 2 de 2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    Demander à FixBot
  3. ASUS UX50V-RX05 Optical Drive Replacement: étape 3, image 1 de 2 ASUS UX50V-RX05 Optical Drive Replacement: étape 3, image 2 de 2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    Demander à FixBot
  4. ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: étape 4, image 1 de 3 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: étape 4, image 2 de 3 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: étape 4, image 3 de 3
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
    Demander à FixBot
  5. ASUS UX50V-RX05 Optical Drive Replacement: étape 5, image 1 de 2 ASUS UX50V-RX05 Optical Drive Replacement: étape 5, image 2 de 2
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
    Demander à FixBot
  6. ASUS UX50V-RX05 Optical Drive Replacement: étape 6, image 1 de 3 ASUS UX50V-RX05 Optical Drive Replacement: étape 6, image 2 de 3 ASUS UX50V-RX05 Optical Drive Replacement: étape 6, image 3 de 3
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
    Demander à FixBot
  7. ASUS UX50V-RX05 Optical Drive Replacement: étape 7, image 1 de 1
    • Carefully lift and remove the plastic cover to avoid damaging anything.
    Demander à FixBot
  8. ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: étape 8, image 1 de 2 ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: étape 8, image 2 de 2
    • Remove the four 5 mm J0 screws surrounding the Optical Drive.
    • Remove the optical drive by pulling it out and away from the connector.
    Demander à FixBot
James
Membre depuis le 02/14/17
663 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 20-2, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 463
