Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Accessing Nokia 3100b Vibrating Unit
Ce dont vous avez besoin
  1. Accessing Nokia 3100b Vibrating Unit, Battery: étape 1, image 1 de 1
    • Make sure your phone is turned off.
    Demander à FixBot
    Ajouter un commentaire
  2. Accessing Nokia 3100b Vibrating Unit: étape 2, image 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Demander à FixBot
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: étape 3, image 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Demander à FixBot
  4. Accessing Nokia 3100b Vibrating Unit: étape 4, image 1 de 1
    • Retrieve your SIM card.
    Demander à FixBot
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: étape 5, image 1 de 1
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
    Demander à FixBot
  6. Accessing Nokia 3100b Vibrating Unit: étape 6, image 1 de 1
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
    Demander à FixBot
  7. Accessing Nokia 3100b Vibrating Unit: étape 7, image 1 de 1
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
    Demander à FixBot
  8. Accessing Nokia 3100b Vibrating Unit: étape 8, image 1 de 1
    • The vibrating unit can now be accessed. Note its location in the phone.
    Demander à FixBot
  9. Accessing Nokia 3100b Vibrating Unit: étape 9, image 1 de 1
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
    Demander à FixBot
  10. Accessing Nokia 3100b Vibrating Unit: étape 10, image 1 de 1
    • The vibrating unit is now removed.
    Demander à FixBot
Sterling Fuentes
Membre depuis le 04/09/10
139 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 29-64, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 37
Total : 1,984
