Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Akai MPK25 Keys Replacement
Ce dont vous avez besoin
  1. Akai MPK25 Keys Replacement, Face Plate: étape 1, image 1 de 1
    • Remove all the selector knob covers by pulling them off.
    Demander à FixBot
    Ajouter un commentaire
  2. Akai MPK25 Keys Replacement: étape 2, image 1 de 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
    Demander à FixBot
  3. Akai MPK25 Keys Replacement: étape 3, image 1 de 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
    Demander à FixBot
  4. Akai MPK25 Keys Replacement: étape 4, image 1 de 3 Akai MPK25 Keys Replacement: étape 4, image 2 de 3 Akai MPK25 Keys Replacement: étape 4, image 3 de 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
    Demander à FixBot
  5. Akai MPK25 Keys Replacement: étape 5, image 1 de 3 Akai MPK25 Keys Replacement: étape 5, image 2 de 3 Akai MPK25 Keys Replacement: étape 5, image 3 de 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
    Demander à FixBot
  6. Akai MPK25 Keys Replacement, Keys: étape 6, image 1 de 2 Akai MPK25 Keys Replacement, Keys: étape 6, image 2 de 2
    • Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
    Demander à FixBot
  7. Akai MPK25 Keys Replacement: étape 7, image 1 de 1
    • Lift the key from the front of the keyboard towards the back in order to remove it completely.
    Demander à FixBot
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
7 autres ont terminé cette réparation.
Will Saba
Membre depuis le 01/11/13
412 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-6, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 46
Total : 11,963
