Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Akai MPK25 LCD Replacement
Ce dont vous avez besoin
    1. Akai MPK25 LCD Replacement, Face Plate: étape 1, image 1 de 1
      • Remove all the selector knob covers by pulling them off.
      Demander à FixBot
      Ajouter un commentaire
    2. Akai MPK25 LCD Replacement: étape 2, image 1 de 1
      • Using needle nose pliers, remove the washers from the four corner selector knobs.
      Demander à FixBot
    3. Akai MPK25 LCD Replacement: étape 3, image 1 de 1
      • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
      Demander à FixBot
    4. Akai MPK25 LCD Replacement: étape 4, image 1 de 3 Akai MPK25 LCD Replacement: étape 4, image 2 de 3 Akai MPK25 LCD Replacement: étape 4, image 3 de 3
      • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
      • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
      Demander à FixBot
    5. Akai MPK25 LCD Replacement: étape 5, image 1 de 3 Akai MPK25 LCD Replacement: étape 5, image 2 de 3 Akai MPK25 LCD Replacement: étape 5, image 3 de 3
      • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
      • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
      Demander à FixBot
    1. Akai MPK25 LCD Replacement, LCD: étape 6, image 1 de 1
      • Using a Phillips #00 screwdriver, remove the four 8.9 mm screws.
      Demander à FixBot
    2. Akai MPK25 LCD Replacement: étape 7, image 1 de 1
      • Using a Phillips #2 screwdriver, remove the one 9.8mm screw holding down the ground wire.
      Demander à FixBot
    3. Akai MPK25 LCD Replacement: étape 8, image 1 de 2 Akai MPK25 LCD Replacement: étape 8, image 2 de 2
      • Using two plastic opening tools, slide the black locking mechanism on the ZIF connector towards you. This will remove the ribbon cable connecting the motherboard to the screen.
      Demander à FixBot
    4. Akai MPK25 LCD Replacement: étape 9, image 1 de 1
      • Lift the screen from either side, removing it from the board.
      Demander à FixBot
To reassemble the display, follow these instructions in reverse order.
3 autres ont terminé cette réparation.
Will Saba
Membre depuis le 01/11/13
412 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-6, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 membres
6 tutoriels rédigés
1 commentaire de tutoriel
Where can I find a new ribbon?
Wise Professor - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 24
Total : 2,524
