Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware M11x Memory Module Replacement
Ce dont vous avez besoin
  1. Alienware M11x Memory Module Replacement, Introduction: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware M11x Memory Module Replacement, Removing the Memory Module: étape 2, image 1 de 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    Demander à FixBot
  3. Alienware M11x Memory Module Replacement, Removing the Memory Module: étape 3, image 1 de 2 Alienware M11x Memory Module Replacement, Removing the Memory Module: étape 3, image 2 de 2
    • Remove the memory module from the memory module connector.
    Demander à FixBot
  4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: étape 4, image 1 de 1
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch in the NEW memory module with the tab in the memory module connector.
    Demander à FixBot
  5. Alienware M11x Memory Module Replacement, Installing the Memory Module: étape 5, image 1 de 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Demander à FixBot
Ligne d'arrivée
2 autres ont terminé cette réparation.
darrius
Membre depuis le 03/26/18
5 213 Réputation
30 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
45 membres
2 003 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 42
Total : 765
