Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware M14xR2 Battery Replacement
Ce dont vous avez besoin
  1. Alienware M14xR2 Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware M14xR2 Battery Replacement: étape 2, image 1 de 3 Alienware M14xR2 Battery Replacement: étape 2, image 2 de 3 Alienware M14xR2 Battery Replacement: étape 2, image 3 de 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    Demander à FixBot
  3. Alienware M14xR2 Battery Replacement: étape 3, image 1 de 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    Demander à FixBot
  4. Alienware M14xR2 Battery Replacement: étape 4, image 1 de 3 Alienware M14xR2 Battery Replacement: étape 4, image 2 de 3 Alienware M14xR2 Battery Replacement: étape 4, image 3 de 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    Demander à FixBot
10 autres ont terminé cette réparation.
Connor Bovee
Membre depuis le 09/30/13
569 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-4, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 42
Total : 11,571
