Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware M15x GPU Replacement
Ce dont vous avez besoin
  1. Alienware M15x GPU Replacement, GPU: étape 1, image 1 de 1
    • Turn the laptop over so that the bottom is facing upward.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware M15x GPU Replacement: étape 2, image 1 de 1
    • Release the battery latch and flip the battery out.
    Demander à FixBot
  3. Alienware M15x GPU Replacement: étape 3, image 1 de 2 Alienware M15x GPU Replacement: étape 3, image 2 de 2
    • Remove the two 4mm screws using a Phillips #1 screwdriver.
    • Remove the compartment door by sliding it away from the battery.
    Demander à FixBot
  4. Alienware M15x GPU Replacement: étape 4, image 1 de 1
    • Remove the four 4mm screws with the Phillips #1 screwdriver.
    Demander à FixBot
  5. Alienware M15x GPU Replacement: étape 5, image 1 de 1
    • Position the laptop vertically so that the hinge is facing up and the laptop is slightly open toward the ground
    • The laptop position should resemble an upside-down V shape.
    • Locate the panel and pry open using a plastic opening tool.
    Demander à FixBot
  6. Alienware M15x GPU Replacement: étape 6, image 1 de 3 Alienware M15x GPU Replacement: étape 6, image 2 de 3 Alienware M15x GPU Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you.
    • Lift the power button panel using the plastic opening tool.
    • Disconnect the ribbon cable by using tweezers to unclip the two small black clips. Remove power button panel.
    Demander à FixBot
  7. Alienware M15x GPU Replacement: étape 7, image 1 de 1
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
    Demander à FixBot
  8. Alienware M15x GPU Replacement: étape 8, image 1 de 2 Alienware M15x GPU Replacement: étape 8, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the 4mm screw from the exhaust port cover.
    • Remove the exhaust port cover entirely.
    Demander à FixBot
  9. Alienware M15x GPU Replacement: étape 9, image 1 de 3 Alienware M15x GPU Replacement: étape 9, image 2 de 3 Alienware M15x GPU Replacement: étape 9, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the two 3mm screws holding the fan in place, then unclip the electrical connection using tweezers.
    Demander à FixBot
  10. Alienware M15x GPU Replacement: étape 10, image 1 de 1
    • Remove the heat sink by loosening the 4 screws with a Phillips #0 screwdriver.
    Demander à FixBot
  11. Alienware M15x GPU Replacement: étape 11, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Remove the GPU from the laptop.
    • When replacing the GPU, it is important to reapply thermal paste in a small line along the length of the chip.
    Demander à FixBot
Tomas Kronmark
Membre depuis le 01/22/18
193 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S11-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 43
Total : 2,307
