Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware M17x Display Assembly Replacement
Ce dont vous avez besoin
  1. Alienware M17x Display Assembly Replacement, Battery: étape 1, image 1 de 2 Alienware M17x Display Assembly Replacement, Battery: étape 1, image 2 de 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware M17x Display Assembly Replacement: étape 2, image 1 de 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    Demander à FixBot
  3. Alienware M17x Display Assembly Replacement: étape 3, image 1 de 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    Demander à FixBot
  4. Alienware M17x Display Assembly Replacement: étape 4, image 1 de 2 Alienware M17x Display Assembly Replacement: étape 4, image 2 de 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    Demander à FixBot
  5. Alienware M17x Display Assembly Replacement, Display Assembly: étape 5, image 1 de 1
    • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
    Demander à FixBot
  6. Alienware M17x Display Assembly Replacement: étape 6, image 1 de 3 Alienware M17x Display Assembly Replacement: étape 6, image 2 de 3 Alienware M17x Display Assembly Replacement: étape 6, image 3 de 3
    • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
    • Use the spudger to remove the siding from the bottom of the frame near the hinges.
    • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
    Demander à FixBot
  7. Alienware M17x Display Assembly Replacement: étape 7, image 1 de 2 Alienware M17x Display Assembly Replacement: étape 7, image 2 de 2
    • Use the plastic opening tool to disconnect the screen from the top mount.
    Demander à FixBot
  8. Alienware M17x Display Assembly Replacement: étape 8, image 1 de 1
    • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
    Demander à FixBot
  9. Alienware M17x Display Assembly Replacement: étape 9, image 1 de 1
    • Tilt the screen forward to expose the connecting wires.
    • Disconnect said wires to then lift the display assembly out of the frame.
    Demander à FixBot
Mosier Locke
Membre depuis le 09/27/18
783 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 34
Total : 1,007
