Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware M17x RAM Replacement
Ce dont vous avez besoin
  1. Alienware M17x RAM Replacement, Battery: étape 1, image 1 de 2 Alienware M17x RAM Replacement, Battery: étape 1, image 2 de 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware M17x RAM Replacement: étape 2, image 1 de 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    Demander à FixBot
  3. Alienware M17x RAM Replacement: étape 3, image 1 de 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    Demander à FixBot
  4. Alienware M17x RAM Replacement: étape 4, image 1 de 2 Alienware M17x RAM Replacement: étape 4, image 2 de 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    Demander à FixBot
  5. Alienware M17x RAM Replacement, RAM: étape 5, image 1 de 2 Alienware M17x RAM Replacement, RAM: étape 5, image 2 de 2
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
    Demander à FixBot
  6. Alienware M17x RAM Replacement: étape 6, image 1 de 2 Alienware M17x RAM Replacement: étape 6, image 2 de 2
    • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
    • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
    Demander à FixBot
  7. Alienware M17x RAM Replacement: étape 7, image 1 de 1
    • Remove the bottom RAM card in a similar manner.
    Demander à FixBot
Mosier Locke
Membre depuis le 09/27/18
783 Réputation
5 tutoriels rédigés
1 commentaire de tutoriel
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 33
Total : 853
