Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware M18x Internal Fan Replacement
Ce dont vous avez besoin
  1. Alienware M18x Internal Fan Replacement, Internal Fan: étape 1, image 1 de 3 Alienware M18x Internal Fan Replacement, Internal Fan: étape 1, image 2 de 3 Alienware M18x Internal Fan Replacement, Internal Fan: étape 1, image 3 de 3
    • Turn the computer over.
    • Slide the battery latch over and lift the battery out.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware M18x Internal Fan Replacement: étape 2, image 1 de 1
    • Unscrew the four indicated screws with a J000 screwdriver.
    Demander à FixBot
  3. Alienware M18x Internal Fan Replacement: étape 3, image 1 de 2 Alienware M18x Internal Fan Replacement: étape 3, image 2 de 2
    • Use the plastic pryer tool to lift the bottom cover off.
    Demander à FixBot
  4. Alienware M18x Internal Fan Replacement: étape 4, image 1 de 2 Alienware M18x Internal Fan Replacement: étape 4, image 2 de 2
    • With the back cover removed, locate the desired fan to replace.
    Demander à FixBot
  5. Alienware M18x Internal Fan Replacement: étape 5, image 1 de 3 Alienware M18x Internal Fan Replacement: étape 5, image 2 de 3 Alienware M18x Internal Fan Replacement: étape 5, image 3 de 3
    • Use a J000 screwdriver to loosen the screws that secure the fan(s).
    • There are three internal fans within the laptop. Locate the correct screws to loosen for the desired fan to replace based on the provided corresponding images.
    Demander à FixBot
  6. Alienware M18x Internal Fan Replacement: étape 6, image 1 de 3 Alienware M18x Internal Fan Replacement: étape 6, image 2 de 3 Alienware M18x Internal Fan Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • The fan will be connected to the motherboard by a cable. Use plastic tweezers to gently unplug this connection.
    Demander à FixBot
  7. Alienware M18x Internal Fan Replacement: étape 7, image 1 de 2 Alienware M18x Internal Fan Replacement: étape 7, image 2 de 2
    • The fan is now fully disconnected from the computer. Gently remove the fan by lifting upwards.
    Demander à FixBot
Jonathan Panella
Membre depuis le 02/21/18
470 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S21-G1, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S21-G1, Banghart Winter 2018
CPSU-BANGHART-W18S21G1
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 940
