Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Alienware X51 RAM Replacement
Ce dont vous avez besoin
  1. Alienware X51 RAM Replacement, Front Panel: étape 1, image 1 de 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
    Demander à FixBot
    Ajouter un commentaire
  2. Alienware X51 RAM Replacement: étape 2, image 1 de 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
    Demander à FixBot
  3. Alienware X51 RAM Replacement, Fan: étape 3, image 1 de 2 Alienware X51 RAM Replacement, Fan: étape 3, image 2 de 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
    Demander à FixBot
  4. Alienware X51 RAM Replacement: étape 4, image 1 de 1
    • Disconnect the Molex KK connector from the fan.
    Demander à FixBot
  5. Alienware X51 RAM Replacement: étape 5, image 1 de 3 Alienware X51 RAM Replacement: étape 5, image 2 de 3 Alienware X51 RAM Replacement: étape 5, image 3 de 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
    Demander à FixBot
  6. Alienware X51 RAM Replacement, Disc Drive: étape 6, image 1 de 2 Alienware X51 RAM Replacement, Disc Drive: étape 6, image 2 de 2
    • Disconnect the optical-drive data and power cable.
    Demander à FixBot
  7. Alienware X51 RAM Replacement: étape 7, image 1 de 1
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
    Demander à FixBot
  8. Alienware X51 RAM Replacement, RAM: étape 8, image 1 de 3 Alienware X51 RAM Replacement, RAM: étape 8, image 2 de 3 Alienware X51 RAM Replacement, RAM: étape 8, image 3 de 3
    • Pull apart the clips that hold the RAM sticks in place.
    • Remove the RAM sticks.
    Demander à FixBot
Kathleen
Membre depuis le 10/02/23
79 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 40
Total : 550
