Introduction
If your Echo Show's screen does not respond or is cracked, you might need to follow this guide to replace it. Before starting, gather a iFixit opening tool. Remember to carefully use your hands to remove the screen, as applying too much pressure might damage the screen further.
Ce dont vous avez besoin
Use the plastic opening tool to gently lift the plastic protector from screen.
6 commentaires de tutoriel
There is no glass replacement. I just got off the phone with Amazon Customer Support and they do not manufacture glass replacement pieces. In other words, if you break the glass you are out of luck. I've submitted feedback (via telephone customer support) for Amazon to begin producing replacement parts and urge you to do the same. Problem with being an early adapter is that what is normal protocol for business (in this case making replacement parts) is not yet developed.
Unfortunate since now I have a $230 awesome piece of tech that has a shattered screen. Customer service gave me $30 :/
You REALLY should remind folks that the front screen is a digitizer and has a delicate ribbon cable coming off it about 1 1/2 inches from the left lower corner. If you use a pry tool there, you’ll slice the ribbon and ruin the digitizer. Don’t ask me how I know! I now have an Echo show with no touch screen capability. Lower left corner about an inch and a half toward the center. No glue there but if you slide a spudger along there, you’ll cut it for sure. Word to the wise……
Yes…. &&^&^$^ ribbon! Where do you get a digitizer. And a power and speaker supply
Any info on the brand / model number for the digitizer assembly, and any info on how to drive it? I would like to replace the “brains” of my Echo Show 10 2nd Gen with something like a Raspberry Pi. (Not too concerned about Touch, Sound, Mic, though if it was possible to make those work, all the better. Really just need video.). TIA!
