Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Amazon Fire HD 10 Front Facing Camera Replacement
Ce dont vous avez besoin
    1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: étape 1, image 1 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: étape 1, image 2 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: étape 1, image 3 de 3
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      Demander à FixBot
      Ajouter un commentaire
    2. Amazon Fire HD 10 Front Facing Camera Replacement: étape 2, image 1 de 1
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      Demander à FixBot
    3. Amazon Fire HD 10 Front Facing Camera Replacement: étape 3, image 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: étape 3, image 2 de 2
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      Demander à FixBot
    4. Amazon Fire HD 10 Front Facing Camera Replacement: étape 4, image 1 de 1
      • Remove the screen and digitizer from the case completely.
      Demander à FixBot
    1. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: étape 5, image 1 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: étape 5, image 2 de 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: étape 5, image 3 de 3
      • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
      • Make sure you place the screws in a safe location nearby.
      Demander à FixBot
    2. Amazon Fire HD 10 Front Facing Camera Replacement: étape 6, image 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: étape 6, image 2 de 2
      • Lift the black plastic cover once the screws are removed.
      • Place aside for later reassembly.
      Demander à FixBot
    3. Amazon Fire HD 10 Front Facing Camera Replacement: étape 7, image 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: étape 7, image 2 de 2
      • Detach the connector using a plastic opening tool or spudger.
      • The camera is still connected to the motherboard.
      Demander à FixBot
    4. Amazon Fire HD 10 Front Facing Camera Replacement: étape 8, image 1 de 2 Amazon Fire HD 10 Front Facing Camera Replacement: étape 8, image 2 de 2
      • Grip the camera and lift up to detach the ZIF connector from the motherboard.
      Demander à FixBot
Jaie Hillery
Membre depuis le 10/07/14
1 774 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 membres
62 tutoriels rédigés
1 commentaire de tutoriel
Can this camera module be upgraded with a better version?
Jimmy Kee - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 49
Total : 1,645
