Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Amazon Fire HD 8 12th Gen Camera Replacement
Ce dont vous avez besoin
  1. Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: étape 1, image 1 de 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: étape 1, image 2 de 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: étape 1, image 3 de 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
    Demander à FixBot
    Ajouter un commentaire
  2. Amazon Fire HD 8 12th Gen Camera Replacement: étape 2, image 1 de 2 Amazon Fire HD 8 12th Gen Camera Replacement: étape 2, image 2 de 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
    Demander à FixBot
  3. Amazon Fire HD 8 12th Gen Camera Replacement, Camera: étape 3, image 1 de 2 Amazon Fire HD 8 12th Gen Camera Replacement, Camera: étape 3, image 2 de 2
    • Using the iFixit opening tool, disconnect the battery from the circuit board.
    Demander à FixBot
  4. Amazon Fire HD 8 12th Gen Camera Replacement: étape 4, image 1 de 3 Amazon Fire HD 8 12th Gen Camera Replacement: étape 4, image 2 de 3 Amazon Fire HD 8 12th Gen Camera Replacement: étape 4, image 3 de 3
    • Disconnect the camera from the motherboard by unplugging the orange wiring.
    • Heat the area of the back camera up loosening the glue holding it in place.
    • Be careful when using hot tools and removing hot parts.
    Demander à FixBot
  5. Amazon Fire HD 8 12th Gen Camera Replacement: étape 5, image 1 de 3 Amazon Fire HD 8 12th Gen Camera Replacement: étape 5, image 2 de 3 Amazon Fire HD 8 12th Gen Camera Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    • Once disconnected from the motherboard and heated up, use tweezers to remove the old camera.
    Demander à FixBot
Jaden Palmer
Membre depuis le 09/06/23
485 Réputation
4 tutoriels rédigés
Équipe
University of Memphis, Team 1-1, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-1, Sneed Fall 2023
UM-SNEED-F23S1G1
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 24
Total : 383
